Set Speed (Unsigned) Command
Character: V
Decimal: 86
Hexadecimal: 0x56
Command Value: New Speed Value
This command sets Speed to the value in the Command Value field. This will cause the current move to ramp up or down to the new speed. This command does not change the Command Position of the axis.
If you wish to simply jog in one direction or another under closed loop control, see the Set Speed (Signed) command.
