Default: 1000
Range: 0 to 65535
The Speed parameter sets the constant speed to be achieved after acceleration. Speed is expressed in position units/second. If the Scale is set so one position unit equals 0.001", a speed of 25 inches per second is expressed as 25000.
Note: When using Acceleration/Deceleration Mode 2, changing the Speed without changing the Acceleration and Deceleration distances will change the acceleration and deceleration rates.
Note: If the Speed is set to zero, the axis will not move.
