Plot Time Area
This area is located in the top right portion of the main window. It holds the Plot Time field for each axis. Refer to this topic for details on its use. This area is updated on startup and each time RMCWin connects to a new RMC.
To the right of the PLOT TIME heading is a column for each axis. You can change these values using the keyboard as described in Changing Data from the Keyboard. Changes are sent to the RMC immediately.
