The following pieces of information associated with a board file can be changed in the manner described below:
Axis Names- Parameters - Plot Times- Default Commands- Module Configuration-
Communication Path- |
Refer to the Changing the Axis Name topic for details. Refer to the Parameter area topic for details. Refer to the Plot Time area topic for details. Refer to the Command area topic for details. All of these settings are modified from the RMC Configuration dialog box. To display this dialog box, from the Tools menu, click Module Configuration. Although the communication path is not actually stored in the board file itself, it is remembered for every board file in the Windows Registry. See Connecting RMCWin to an RMC for details on changing this option. |
