Board files are used to store the following pieces of information:
Names of each axis
Parameters of each axis (configuration word, scale, offset, etc.)
Command fields for each axis, except the Command itself (Mode through Command Value).
Plot times for each axis.
Hardware configuration of the RMC. This includes:
List of the physical modules included (e.g. PROFIBUS-DP, RMC100 CPU, two MDTs).
List of options for these modules. This includes all settings modified through the RMC Configuration dialog box (e.g. PROFIBUS station address, MDT blanking periods, number of SSI data bits, analog board channel assignments).
Refer to Using Multiple RMCs for general board file information.
To save a board file:
On the File menu, click Save As.
In the File name box, enter the name of the file.
Click Save.
To load a board file:
On the File menu, click Open.
Click Open. The file will be loaded. If the new board file uses a different communication path, then the previous communication path be closed and the new communication path will be opened.
To load just everything except the hardware configuration from a board file:
On the File menu, click Load Parameters.
Click Open. The parameters, commands, plot times, and axis names will be loaded from the selected board file into the currently open board file. The filename will not change on the currently open board file.
