Type: |
Address: |
RMC75: %MDn.59, where n = 8 + the axis number RMC150: %MDn.59, where n = 8 + the axis number RMC200: %MDn.410, where n = 256 + the axis number |
System Tag: |
How to Find: |
Axes Status Registers Pane, All tab: Target |
Data Type: |
Description
The Cycles status register gives the whole number of cycles that the current position sine move, trapezoid move, or curve has completed. After a sine/trapezoid move or curve has completed or been interrupted, this will remain at its current value. This value is reset each time a position sine/trapezoid move or curve is started.
For continuous moves (without a fixed number of cycles), this value will wrap to zero after it reaches 10,000,000 and then continue incrementing. For moves with a fixed number of cycles, this value will not go beyond the requested cycle count.
If you need more status information on the sine/trapezoid move or curve, such as the cycle fraction, you can use the Status Block defined by the Sine Start (72), Trapezoid Start (130), and Curve Start Advanced (88) commands.
Status Registers | Sine Start (72) | Sine Start (Prs/Frc) (76) | Curve Start (86) | Curve Start (Prs/Frc) (87) | Trapezoid Start (130)
