RMCLink C++ Wrapper Class CRMCLink::ReadLFile Method |
Reads one or more integer (L) registers from the controller. Use ReadLFile to read RMC100 registers (which are all integer registers), or to read RMC70, RMC150, or RMC200 registers in integer format. Compare with ReadFFile.
HRESULT ReadLFile( UINT file, UINT element, UINT count, long* pData ); |
count
The number of registers to read.
pData
Pointer to an array of long values with at least count elements. The register values that are read will be placed into this array.
E_OUTOFMEMORY |
E_INVALIDARG |
One of the file, element, or count parameters are out of range. |
RMCLINK_E_DISCONNECTING |
RMCLINK_E_DISCONNECTED |
RMCLINK_E_SOCK_INTERNAL |
RMCLINK_E_CANCELLED |
RMCLINK_E_TIMEOUT |
RMCLINK_E_SOCK_ERROR_RD |
RMCLINK_E_SOCK_INV_RD_LEN |
RMCLINK_E_SOCK_ERROR_WR |
RMCLINK_E_SOCK_INV_WR_LEN |
RMCLINK_E_CE_IOE |
Serial IOE error. |
RMCLINK_E_CE_FRAME |
Serial framing error. |
RMCLINK_E_CE_BREAK |
Serial Break error. |
RMCLINK_E_CE_OVERRUN |
Serial overrun. |
RMCLINK_E_CE_RXOVER |
Serial receive overrun. |
RMCLINK_E_CE_RXPARITY |
Serial parity error. |
RMCLINK_E_CE_TXFULL |
Serial transmitter full. |
RMCLINK_E_CONN_BROKEN |
RMCLINK_E_PARTIAL_WRITE |
RMCLINK_E_BAD_ADDRESS |
RMCLINK_E_USB_SETTIMEOUT |
RMCLINK_E_USB_OP_ABORT |
RMCLINK_E_USB_DISCONNECT |
The following code example illustrates the use of the ReadLFile method.
CRMCLink* pRMC = CRMCLink::CreateEthernetLink(CRMCLink::dtRMC100, _T("192.168.0.28"));
// Read L0:1-2 (Axis 0 Target and Actual Positions)
long alData[2];
hr = pRMC->ReadLFile(CRMCLink::fn100StatusAxis0, 1, 2, alData);
printf("Target Position = %.3f, Actual Position = %.3f\n",
afData[0], afData[1]);
CRMCLink Class | RMCLink C++ Wrapper Class | ReadFFile
