RMCLink C++ Wrapper Class CRMCLink::ReadFFile Method |
Reads one or more floating-point (F) registers from the controller. Use ReadFFile to read floating-point registers from the RMC70, RMC150, or RMC200. Compare with ReadLFile.
HRESULT ReadFFile( UINT file, UINT element, UINT count, float* pData ); |
count
The number of registers to read.
pData
Pointer to an array of float values with at least count elements. The register values that are read will be placed into this array.
Notice that all RMC100 registers are integers. Therefore, using this method to read data from the RMC100 will simply convert the values to floating point. For example, reading a value of 25 will be stored as a float in the output array as 25.0.
For details on integer (L) and floating-point (F) registers and how to read from and write to both, see RMC100 Register Data Types or RMC70, RMC150 and RMC200 Register Data Types.
E_OUTOFMEMORY |
E_INVALIDARG |
One of the file, element, or count parameters are out of range. |
RMCLINK_E_DISCONNECTING |
RMCLINK_E_DISCONNECTED |
RMCLINK_E_SOCK_INTERNAL |
RMCLINK_E_CANCELLED |
RMCLINK_E_TIMEOUT |
RMCLINK_E_SOCK_ERROR_RD |
RMCLINK_E_SOCK_INV_RD_LEN |
RMCLINK_E_SOCK_ERROR_WR |
RMCLINK_E_SOCK_INV_WR_LEN |
RMCLINK_E_CE_IOE |
Serial IOE error. |
RMCLINK_E_CE_FRAME |
Serial framing error. |
RMCLINK_E_CE_BREAK |
Serial Break error. |
RMCLINK_E_CE_OVERRUN |
Serial overrun. |
RMCLINK_E_CE_RXOVER |
Serial receive overrun. |
RMCLINK_E_CE_RXPARITY |
Serial parity error. |
RMCLINK_E_CE_TXFULL |
Serial transmitter full. |
RMCLINK_E_CONN_BROKEN |
RMCLINK_E_PARTIAL_WRITE |
RMCLINK_E_BAD_ADDRESS |
RMCLINK_E_USB_SETTIMEOUT |
RMCLINK_E_USB_OP_ABORT |
RMCLINK_E_USB_DISCONNECT |
The following code example illustrates the use of the ReadFFile method.
float afData[2];
afData[0], afData[1]);
CRMCLink Class | RMCLink C++ Wrapper Class | ReadLFile
