RMCLink COM Component RMCLink.Disconnect Method |
Closes the connection, if one has been established, associated with this RMCLink object.
Sub Disconnect () |
Dim instance As RMCLink
instance.Disconnect |
On serial connections, the serial port will be released for use by other applications. On Ethernet connection, the TCP/IP connection will be closed.
This method is synchronous, which means that it will not return until the link is disconnected. However, disconnecting generally takes only a fraction of a second.
WARNING: For Ethernet connections, it is highly recommended that the connection not be disconnected and re-connected between transactions. Doing so will have lower performance, and more importantly, each call to Connect() will consume a TCP connection in the Windows operating system. This TCP connection will not be fully released by the operating system until typically 2 minutes after Disconnect() is called. Therefore, it is possible to consume all available TCP connections by repeated calls to Connect()/Disconnect() and as a result be unable to re-connect over RMCLink or even adversely affect other applications running on the same PC.
Error Code |
rmcEAlreadyDisconnected = 1007 |
The link was already disconnected. To avoid this error, avoid calling Disconnect when the link is already disconnected. Use IsConnected if you are not sure if the link is connected or not. |
The following code example illustrates the use of the Disconnect method.
Dim data As Variant
Dim srv, rmc, data
