Selecting the Data to Plot
All plots read from the RMC contain the following information:
In addition, ACTUAL SPEED and TARGET SPEED are calculated from the ACTUAL POSITION and TARGET POSITION values and stored in the plot.
The RMC can provide two more pieces of data; the user chooses what data is collected using the Plot Options dialog box. To use this dialog box:
  1. If you are going to change the extra graph information on only one axis, select a field in the axis.
  2. On the Tools menu, click Plot options.
  3. Click the option button of the data you want to include. The options are described below.
  4. If you wish to change the extra graph information for all axes, select the Set for all axes check box.
  5. Click OK.
  6. Trigger a new graph to be stored by the module. This requires making a new move because the new information is not collected until the module begins a new graph.
The extra pieces of information that can be included are:
Note: Commands given from RMCWin are not included in the plot data.
Note: The Internal Speeds option requires RMC100 CPU firmware dated 20010205 or newer.
Note: The Integral Drive option requires RMC100 CPU firmware dated 20020419 or newer.
