Connecting RMCWin to an RMC
Communication Driver Status
The main window's status bar has a pane called the Communication pane. This pane shows the current communication path and the state of that communication path (for example, "COM1: Offline"). A path can be in any of the following states:
State
Description
Closed
RMCWin is not connected to an RMC, and it is not using the communication path at all.
Offline
RMCWin is not connected to an RMC, but it is polling the communication path for an RMC to become available.
Connecting
RMCWin detected an RMC, but is in the process of connecting and validating the RMC configuration.
Online
RMCWin is currently connected to an RMC.
Loader
RMCWin is currently connected to an RMC, but the RMC is running its loader firmware. The only operation allowed in the loader is downloading new firmware. See Downloading New RMC100 Firmware for details on updating the firmware.
Picking the Right Communication Driver
RMCWin offers numerous ways to connect to an RMC. All of these ways use one of three drivers, each of which is listed below. Click the link following each for a detailed description and wiring diagrams:
Note: If your computer has a firewall, it may prevent RMCWin from finding RMC100s on your Ethernet network from the Communications tab in the Options dialog. See the Setting the Firewall to Allow RMC100 Ethernet Browsing topic for details.
Selecting and Configuring a Communication Driver
The first way to select or configure a communication driver is to use the Communication tab of the Options dialog box.
To use the Communication tab:
  1. Start RMCWin.
  2. On the Tools menu, click Options, and then click the Communication tab.
    You can also double-click the Communication pane of the main window's status bar, or right-click this pane and then click Communication Options from the shortcut menu.
  1. Select the appropriate driver and options. See Using the Communication Options Tab for details.
  2. Click OK.
Another way to change some of the communication options is to use the Communication pane shortcut menu. Options in this menu include:
To use the Communication pane shortcut menu:
  1. Start RMCWin.
  2. On the main window's status bar, right-click the Communication pane.
    A shortcut menu will appear with the options described above.
  1. In the shortcut menu, click the option you want to use.
