Status Word Bit Map (Quadrature)
The axis Status word contains 16 bits of information about the status of the axis. The hexadecimal table below provides an easy way to convert hexadecimal numbers to bit patterns.
* Can cause a Soft or Hard Stop if the corresponding bits are set in the Auto Stop field.
** Will cause either a Soft or Hard Stop depending how Auto Stop bits 5, 6, and 7 are set.
