Default: 0
Range: Valid Pressure Units
Pressure Set B is used by Pressure Set Mode as the pressure below which the axis will stop regulating pressure. When the Actual Pressure becomes equal to or less than Pressure Set B, the axis stops regulating pressure and returns to position mode. There are two ways to set this field:
Issue a Set Pressure (^) command, and the third command parameter will be the new value for Pressure Set B.
Issue a Set Pressure Set B (_) command, and the Command Value will be the new value for Pressure Set B.
Note: Although Pressure Set B is used as the threshold below which an axis will leave pressure regulating mode, it is not used as the threshold above which the axis enters pressure regulating mode; the Pressure Set A parameter is used for this.
Note: Pressure Set A must be set greater than or equal to Pressure Set B.
