Default: 0
Range: Valid Pressure Units
Pressure Set A is used by Pressure Set Mode as the pressure above which the axis will begin regulating pressure. When a command is issued to the position axis with the Pressure Mode bit set, then the pressure is monitored. When the Actual Pressure becomes equal to or greater than Pressure Set A, the axis begins regulating pressure. There are two ways to set the this field:
Issue a Set Pressure (^) command, and the second command parameter will be the new value for Pressure Set A.
Issue a Set Pressure Set A (|) command, and the Command Value will be the new value for Pressure Set A.
Note: Although Pressure Set A is used as the threshold above which an axis can enter pressure regulating mode, it is not used as the threshold below which the axis leaves pressure regulating mode; the Pressure Set B parameter is used for this.
Note: Pressure Set A must be set greater than or equal to Pressure Set B.
