Update Flash Command
Character: U
Decimal: 85
Hexadecimal: 0x55
Command Value: Unused
This command instructs the RMC to write all parameters, profiles, configuration data, Input-to-Event table entries, Events Steps, and LCD screens to Flash memory for storage in case of power loss or reset. While a Flash update is in progress, the green CPU LED will flash. Removing power while the LED is still flashing will result in the parameters being lost.
Note: The Update Flash command does not write the splines to Flash. For details on writing splines to Flash, see the Update Flash Segment command.
