Update Flash Segment Command
Character: u
Decimal: 117
Hexadecimal: 0x75
Command Value: Segment to Write
This command instructs the RMC to write a certain segment or segments to Flash memory for storage in case of power loss or reset. While a Flash update is in progress, the green CPU LED will flash. Removing power while the LED is still flashing will result in the parameters being lost.
The Command Value determines which segments will be written to Flash:
Command Value
Segment to Write
All segments except splines.
1
Splines only.
For details on writing all segments except splines to Flash, see the Update Flash Command.
