Character: ]
Decimal: 93
Hexadecimal: 0x5D
Command Value: Mask of Digital Output Bits to Clear
This command uses the Command Value to determine which outputs to reset. It uses the Command Value in the same manner as the Set Outputs command, except that it resets each output that corresponds to a bit set in the Command Value.
See also: Set Outputs
