Quit Events Command
Character: Q
Decimal: 81
Hexadecimal: 0x51
Command Value: Unused
This command stops the event control sequence on the axis the command is issued to. Any motion commands in progress on the axis are not stopped. Therefore, if an axis is currently moving to 4.000”, it will continue moving to that position; if an axis is in open loop with 1.000V drive, the drive will continue holding that drive, etc. If you desire to stop the axis at the same time, look at the Halt and Disable Drive Output commands.
Note: RMC100 CPU firmware dating prior to 19980414 supports event sequences only on position axes, issuing this command to a pressure or force axis will result in a parameter error.
