Follow Spline Segment Command
Character: f
Decimal: 102
Hexadecimal: 0x66
Command Value: Unused
This command will begin following the next available spline segment. If there is only one spline segment loaded, then this segment will be repeated even if it has already been followed. See also the Follow Spline Relative command.
This command does not use Accel, Decel, Speed, and Command Value. These unused fields should be set to 0 for forward compatibility. However, the following bits of the Mode word are used: Graph Disable, Monitor Pressure, Rotational, and Geared bits. Each should be adequately described in the Mode word topic, but see the description below for more information on Gearing a spline.
The In Position bit of the Status will be cleared when this command begins and will be set when the axis reaches the end of the spline. The State A and State B status bits will be cleared throughout the spline.
The axis must already be at the position of the first spline point (the Follow Spline Relative command does not require this). This can be ensured by the programmable controller by giving a Go (G) command to the first location and waiting for the In Position status bit to be on or for State A and State B status bits to both be off. This is left as the user’s responsibility to allow the user to control the manner that the axis moves to the first location.
This command can fail for the following reasons, as indicated by the Parameter Error bit in the Status word:
The rate at which the axis moves through the spline is determined in the following manner:
Note: In RMC100 CPU firmware dated prior to 19990625 (or beta firmware dated prior to 19980827B) the Geared Mode bit is ignored and therefore assumed to be cleared.
The gearing relationship works as follows:
Addendum for Special Firmware ’r;SI’ (e.g. 19980827SI)
This firmware is available only on request, as it useful only for special applications. This firmware includes superimposed mode. The above description of this command is appended in the following ways:
