Start Events Command
Character: E
Decimal: 69
Hexadecimal: 0x45
Command Value: Event Step to Start Execution
This command starts an event step sequence at the step specified in the Command Value field. If the axis already was in the middle of an event sequence, that sequence will end and the new event sequence will begin.
Note: RMC100 CPU Firmware dating prior to 19980414 supports event sequences only on position axes. Issuing this command to a pressure or force axis will result in a parameter error.
