Load Parameters Command
The board files for the RMC contain the following pieces of information:
When opening a board file using the Open command, the entire board file is loaded. However, if RMCWin is connected to an RMC and the hardware configuration in the RMC does not match that in the board file, the board file cannot be loaded. As a result, the Resolve Configuration Conflict dialog box is displayed to allow the user to choose an action. See Resolve Configuration Conflict Dialog Box for details.
This situation can be avoided using this command, which does not open the new board file, but instead transfers everything except the hardware configuration from the selected board file into the currently open board file. Therefore this command only loads the following:
