In Look-only mode, the user cannot make changes to the module. This prevents the user from changing any parameters or issuing any commands. It is still possible to view all data.
To toggle look-only mode:
On the Tools menu, click Options, and then click the Preferences tab.
Select or clear the Look-only check box to enable or disable look-only mode.
Click OK.
Notice that this setting is saved so that it will be remembered the next time that RMCWin is started.
