Because the Address Tool updates as you select fields in other windows, you will often want to ensure that the Address Tool remains visible, even when you are working in other windows. One way to do this is to move and/or resize all windows so that the Address Tool will never be behind any windows. However, an easier solution in many cases is to use the Always on Top feature of the Address Tool. When this feature is turned on, the Address Tool will never go behind other windows, even when it is not active.
To turn on or off the Always on Top feature:
Right-click the Address Tool title bar to display its shortcut menu.
On the shortcut menu, click Always on Top.
Note: Most RMCWin windows have the Always on Top feature, which is enabled in the same way for each window. Notice that no guarantee can be made as to which window will be on top out of multiple windows designated as Always on Top.
