Delta Technical Support Numbers
Phone: 360-254-8688 (24-hour emergency support available)
Fax: 360-254-5435
www.deltamotion.com
support@deltamotion.com
RMC Return for Repair
If you need to return the RMC for repair, please contact Delta prior to shipment for an RMA number. Returned RMCs must be packaged in static protection material and have the RMA number clearly marked on the outside of the package. Please include a short note explaining the problem. Send the module to:
Delta Computer Systems, Inc.
1818 SE 17th St
Battle Ground, WA 98604
Returns
Contact Delta for details on returning items. An RMA number must be issued before an item is returned.
