Default: 100
Range: -32768 to 32767
Note: Use positive Feed Forward and Gain values if the pressure increases in the extend direction, and negative values if the pressure increases in the retract direction.
Same as Extend Feed Forward, except it is used when retracting.
Note: Retracting is the direction that returns decreasing Transducer Counts.
