Format: 0AAA RRRR 01NN NNNN
R Used for Status Area Request
N Used for Command Index described below
A Used only by Communication Digital I/O; 0 for PROFIBUS-DP
The ASCII commands can be used to send any command that can be sent from RMCWin. These commands are listed in the Command Field topic. To send an ASCII command, use the hex value for the commands listed in the table in the Command Field topic and use the desired Status Area Request value. For example, to send a Change Deceleration (D) command (hexadecimal 0x44) using a Status Area Request value of 2, you would send a command register of 0x0244.
The command data sent represents the Command Value of the ASCII command being sent, if one is required.
