This topic describes the operators available in the RMC expressions. For details on using the operators, see the Assignment Expressions and Logical Expressions topics.
Operator |
Operates on these Data Types |
Notes |
Assigns the value of the expression on the right-hand side to the register on the left-hand side. Required in all assignment expressions. |
All Data Types |
The assignment operator is required in the Expression command. |
Addition |
REAL, DINT |
Subtraction |
REAL, DINT |
Multiplication |
REAL, DINT |
Division |
REAL, DINT |
Integer Modulo Gives the remainder of a division of whole numbers. |
DINT |
Examples: 12 MOD 5 will return 2. 61 MOD 10 will return 1. 5 MOD 5 will return 0. |
Opening parenthesis. |
All Data Types |
The number of opening parentheses must match the number of closing parentheses. |
Closing parenthesis. |
All Data Types |
Equal To (not for assigning values) |
All Data Types |
Cannot be used for assignment. |
Not Equal |
All Data Types |
Less Than or Equal To |
REAL, DINT |
Less Than |
REAL, DINT |
Greater Than |
REAL, DINT |
Greater Than or Equal To |
REAL, DINT |
AND |
Logical and Bitwise AND |
DWORD, DINT, BOOL |
The data types of the operands must match. |
OR |
Logical and Bitwise OR |
DWORD, DINT, BOOL |
NOT |
Logical and Bitwise NOT |
DWORD, DINT, BOOL |
XOR |
Logical and Bitwise Exclusive OR |
DWORD, DINT, BOOL |
Opening bracket for indexing item in an array, e.g. MyVar[i] or _Axis[0].ActPos. |
All Data Types |
The number of opening brackets must match the number of closing brackets. |
Closing bracket for indexing item in an array, e.g. MyVar[i] or _Axis[0].ActPos. |
All Data Types |
Exponentiation |
REAL |
Example: 3**6 is three to the sixth power. If you are calculating polynomials, consider using the POLY function. |
Precedence |
Operation |
Symbol |
HIGHEST |
Parenthesization |
(expression) |
Function Evaluation |
identifier(argument list) ln(a), max(x,y) etc. |
Negation Complement |
- NOT |
Exponent |
Multiply Divide Modulo |
* / MOD |
Add Subtract |
Comparison |
Equality Inequality |
Boolean AND |
AND |
Boolean Exclusive OR |
XOR |
Boolean OR |
OR |
Lowest |
Assignment |
Expressions Overview | Functions | Data Types
