Curve Storage Capacity
Curves are stored in the Curve Store. The Curve Store can hold a maximum of 128 curves. The non-volatile storage capacity for curves is less. The curve storage capacity varies by controller, as shown below. When a curve is added, the Event Log will display the size of the curve in bytes.
Controller
Curve Store Capacity
RMC200 Lite
16 MB
RMC200 Standard
64 MB
RMC150E
8 MB
RMC75E
8 MB
RMC75S
256 KB
RMC75P
256 KB
Non-Volatile Memory
The curves in the Curve Store will be lost when power is removed from the RMC. However, curves can be saved to non-volatile Flash memory if they were downloaded from the Curve Tool or added using the Curve Add command with the Permanent life cycle option.
The size consumed by curves in Flash is as follows, where N is the number of points in the curve:
Curve Type
Size
Constant, Linear
8xN + name length + description length + 40 bytes
Cubic
16xN + name length + description length + 40 bytes
The curves share the same Flash storage as the entire RMC project, including axis parameters, plot templates, variable table defaults, user programs, and curves. The total Flash size is as follows:
Controller
Flash Size
RMC200
6016 KB
RMC150E
1024 KB
RMC75E (1.1G and newer)
1024 KB
RMC75E (1.1F and older)
256 KB
RMC75P
96 KB
RMC75S
96 KB
Curve Store Capacity Quick Charts
The following charts show the maximum allowable sizes for equal-length simple cubic curves in the various RMC controllers with various numbers of curves. This assumes curves are added via the Curve Add command with the Partial Curve - Equally Spaced format. This will fill the curve store, but the curves will not fit in non-volatile memory.
Simple Cubic Curves,
Max Length for:
RMC200 Standard
RMC200 Lite
RMC75E
RMC150E
RMC75P
RMC75S
Single Curve
1,677,715 points
419,424 points
209,708 points
8,186 points
8 Equal-length Curves
372,819 points
93,199 points
46,596 points
1,518 points
16 Equal-length Curves
197,370 points
49,336 points
24,665 points
783 points
50 Equal-length Curves
65,784 points
16,440 points
8,216 points
253 points
80 Equal-length Curves
41,416 points
10,348 points
5,170 points
156 points
128 Equal-length Curves
26,002 points
6,494 points
3,244 points
95 points
Curve Store Memory Uses
The Curve Store contains a pool of memory as described above. There are four operations that will consume Curve Store memory:
This buffer is allocated when a partial curve download is started. This buffer is used to re-assemble the parts submitted individually into a single curve data structure. This buffer is freed up after the final part is added and the curve is ready, or when a new partial curve download is started—cancelling the existing download—or when the Curve Delete All (85) command is issued. Notice that no more than one re-assembly buffer is allocated at a time.
This buffer is allocated when a curve is being added if the interpolation method requires extra memory to prepare the curve for interpolation. This currently only applies to curves using the cubic interpolation method. This buffer is freed up when the curve adding is completed. Like the re-assembly buffer, no more than one computation buffer is allocated at a time.
Each curve that has been successfully added to the Curve Store will occupy a block of memory in the Curve Store until that curve is deleted. See the Curves Overview topic for details on deleting curves. There can be up to 128 curve objects in the curve store at once, each potentially a different size.
Download Buffer Size
This buffer is allocated for each curve downloaded from the Curve Tool only for the duration of that curve download. No more than one download buffer is allocated at a time. The download buffer size depends on the interpolation type as shown below, where N is the number of points in the curve:
Curve Type
Size
Constant, Linear
Cubic
Re-assembly Buffer Size
As described in the Creating Large Curves using the Curve Add Command topic, the partial curve data format has a field called Total Curve Data Length (TCDL). This field indicates the number of registers in the re-assembled curve data. Using the TCDL value, the size of the re-assembly buffer size can be found using the following formulas:
RMC200
RMC75E
RMC150E
RMC75P
RMC75S
TCDL x 4 + 16 bytes
TCDL x 4 + 32 bytes
TCDL x 4 + 8 bytes
Computation Buffer and Curve Object Sizes
The amount of space required for the computation buffer and curve object depends on several factors. The most important factor is the interpolation method to be used. Formulas for calculating the memory requirements are given below.
Constant and Linear Interpolated Curves
These two types of curves do not require a computation buffer. The curve object sizes are given in the chart below:
RMC200
RMC75E
RMC150E
RMC75P
RMC75S
Curve Size
8xN + 112 bytes
8xN + 112 bytes
8xN + 88 bytes
Cubic Interpolation Curves
The memory requirements for cubic curves depend on the options and characteristics of the curve. The term "simple curve" below means that the curve has no fixed-velocity points or constant-velocity segments, which can be added by the Advanced curve data format or the Overshoot Protection and Auto-Constant Velocity interpolation options. The term "advanced curve" below describes a curve that does have at least one fixed-velocity point or constant-velocity segment.
The following charts show the memory requirements for simple curves:
Simple Curves with Zero- or Natural-Velocity Endpoints
RMC200
RMC75E
RMC150E
RMC75P
RMC75S
Curve Size
20xN + 160 bytes
20xN + 144 bytes
20xN + 120 bytes
Computation Buffer Size
16xN + 48 bytes
16xN + 64 bytes
8xN + 24 bytes
Simple Cyclic Curves
RMC200
RMC75E
RMC150E
RMC75P
RMC75S
Curve Size
20xN + 120 bytes
20xN + 120 bytes
20xN + 96 bytes
48xN - 32 bytes
48xN + 32 bytes
24xN + 8 bytes
The sizes for advanced curves are difficult to compute, but will generally be at least as large as the values shown in the Simple Curves with Zero- or Natural-Velocity Endpoints chart above. The best way to determine the size required by an advanced curve is to add the curve and look at the size reported in the Event Log.
Memory Requirement Examples
Example 1
How much Curve Store memory is used to add a 10,000-point Simple Cubic Curve with Zero-Velocity Endpoints to the RMC75E using the Curve Add command?
Downloading this curve using the Curve Add command will require the Partial Curve Data Format, and therefore require a re-assembly buffer. If we use the Partial Curve – Evenly-Spaced format (see Curve Data Formats), then the Total Curve Data Length will be 10,004 registers. Therefore, our re-assembly buffer will require 4xTCDL + 32 or 40,048 bytes.
Next, because this curve uses the cubic interpolation method, the curve will require a Computation Buffer. Using the charts above, we find that the Computation Buffer for a Simple Cubic Curve with Zero-Velocity Endpoints will require 16xN+64 bytes or 160,064 bytes.
Finally, the curve object itself will require 20xN+144 bytes or 200,144 bytes. Therefore, the Curve Store must have 40,048 + 160,064 + 200,144 or 400,256 bytes available to successfully download this curve. Notice however, that after the curve has been added, the re-assembly and computation buffers will be freed up, leaving only 200,144 bytes used for this curve from the Curve Store.
Example 2
How much Curve Store memory is used to add fifty (50) Cubic Curves with Zero-Velocity Endpoints—each with 10,000 points—to the RMC75E using the Curve Tool?
When downloading a curve using the Curve Tool, each download will require a Download Buffer of 16 bytes per point plus curve name and description length plus 40 bytes. If we assume that each curve’s name and description use 20 characters total, then each 10,000-point Cubic curve will require a download 160,060 bytes. The Computation Buffer and Curve Object will have the same sizes as calculated in Example 1, 160,064 bytes and 200,144 bytes respectively.
When each curve is downloaded, the Download Buffer will be allocated, then the Curve Object, and finally the Computation Buffer. Once the curve is successfully added, the Download and Computation Buffers will be freed up, leaving only the Curve Object in the Curve Store. Each of the 50 curves is downloaded in this manner. Therefore, the approximate total Curve Store memory requirement for 50 of these curves is 50 Curve Objects, 1 Download Buffer, and 1 Computation Buffer, which is ( 200,144 x 50 ) + 160,060 + 160,064 = 10,327,324 bytes or 9.8 MB. Notice that this exceeds the 8MB Curve Store capacity available on the RMC75E. Therefore, these curves cannot be downloaded to this controller.
Fragmentation of the Curve Store Memory
After adding and deleting curves, the Curve Store memory may become fragmented, limiting the memory available for adding curves. To clear the memory completely, use the Curve Delete All (85) command.
Curves Overview | Curve Data Formats
