RMCLink Address Map for the RMC70 |
When using RMCLink, the addresses of the registers in the RMC70 are specified with a File number and an Element number. Use this address map to find the correct File and Element values for the data items in the RMC70 series motion controllers. Notice that the file and element used by RMCLink for the RMC70 is the same as the addressing convention used by RMCTools. For other RMCs, refer to the RMCLink Address Map topic.
In Visual Basic, Visual C++, and the .NET languages, the File Constants (in the help Contents, see the Enumeration Types book for the language you are using) can be used in the File parameter of the Read and Write methods to make the code more readable. The File Constants cannot be used in scripting or VBA.
Refer to the RMCTools help for details on how to use the various registers in the RMC70.
File |
File Constant |
7 |
fn70ControllerInfo |
Basic controller read-only information |
8 |
fn70StatusAxis0 |
9 |
fn70StatusAxis1 |
Control/Reference Axis 1 Status Registers - Identical to file 8 |
10 |
fn70StatusAxis2 |
Reference Axis 2 Status Registers - Identical to file 8 |
11 |
fn70StatusAxis3 |
Reference Axis 3 Status Registers - Identical to file 8 |
12 |
fn70ParameterAxis0 |
The Parameter Registers are axis-dependent.
13 |
fn70ParameterAxis1 |
Control/Reference Axis 1 Parameter Registers - Identical to file 12 |
14 |
fn70ParameterAxis2 |
Reference Axis 2 Parameter Registers - Identical to file 12 |
15 |
fn70ParameterAxis3 |
Reference Axis 3 Parameter Registers - Identical to file 12 |
16 |
fn70CommandArea |
Note: The RMC70 command area registers were originally located only in file 16. However, to add more command parameters, the command area was changed to file 25. The file 16 command area is still available for backwards compatibility with earlier versions of RMC70s that did not support the new larger command area (9 command parameters per command). The file 16 registers should not be used to issue commands that require more than 5 command parameters.
17 |
fn70IndDataMap |
Note:
18 |
fn70IndDataValues |
Note:
19 |
fn70AxisAssign |
Axis Assignment - Do not attempt to change these registers. They are used by the RMC70 for assigning axes to hardware. |
20 |
fn70ControllerRegs |
21 |
fn70CommConfig |
These registers are module-dependent.
RMC75S
RMC75P
RMC75E
23 |
fn70DiscreteIO |
Note:
24 |
fn70TaskStatus |
25 |
fn70LrgCommandArea |
26 |
fn70AnalogInputs |
Analog Inputs |
27 |
fn70AxisNames |
Axis Names |
30 |
fn70ImageArea |
Image Area |
31 |
fn70PlotSchema |
32 |
fn70Plot0CfgSts |
33 |
fn70Plot1CfgSts |
Plot 1 Configuration - Identical to file 32 |
34 |
fn70Plot2CfgSts |
Plot 2 Configuration - Identical to file 32 |
35 |
fn70Plot3CfgSts |
Plot 3 Configuration - Identical to file 32 |
36 |
fn70Plot4CfgSts |
Plot 4 Configuration - Identical to file 32 |
37 |
fn70Plot5CfgSts |
Plot 5 Configuration - Identical to file 32 |
38 |
fn70Plot6CfgSts |
Plot 6 Configuration - Identical to file 32 |
39 |
fn70Plot7CfgSts |
Plot 7 Configuration - Identical to file 32 |
40 |
fn70Plot0DynUA |
41 |
fn70Plot1DynUA |
Plot 1 Dynamic Plot Upload Area - Identical to file 40 |
42 |
fn70Plot2DynUA |
Plot 2 Dynamic Plot Upload Area - Identical to file 40 |
43 |
fn70Plot3DynUA |
Plot 3 Dynamic Plot Upload Area - Identical to file 40 |
44 |
fn70Plot4DynUA |
Plot 4 Dynamic Plot Upload Area - Identical to file 40 |
45 |
fn70Plot5DynUA |
Plot 5 Dynamic Plot Upload Area - Identical to file 40 |
46 |
fn70Plot6DynUA |
Plot 6 Dynamic Plot Upload Area - Identical to file 40 |
47 |
fn70Plot7DynUA |
Plot 7 Dynamic Plot Upload Area - Identical to file 40 |
48 |
fn70Plot0StaticUA |
Static Plot Upload Area - Plot 0, Sample Set 0 (elements 0-4095 in File 48) |
49 |
fn70Plot1StaticUA |
Static Plot Upload Area - Plot 0, Sample Set 1 (elements 0-4095 in File 49) |
50 |
fn70Plot2StaticUA |
Static Plot Upload Area - Plot 0, Sample Set 2 (elements 0-4095 in File 50) |
51 |
fn70Plot3StaticUA |
Static Plot Upload Area - Plot 0, Sample Set 3 (elements 0-4095 in File 51) |
52 |
fn70Plot4StaticUA |
Static Plot Upload Area - Plot 1, Sample Set 0 (elements 0-4095 in File 52) |
53 |
fn70Plot5StaticUA |
Static Plot Upload Area - Plot 1, Sample Set 1 (elements 0-4095 in File 53) |
54 |
fn70Plot6StaticUA |
Static Plot Upload Area - Plot 1, Sample Set 2 (elements 0-4095 in File 54) |
55 |
fn70Plot7StaticUA |
Static Plot Upload Area - Plot 1, Sample Set 3 (elements 0-4095 in File 55) |
56 |
fn70VarCurValues |
64 |
fn70VarInitValues |
68 |
fn70VarAttributes |
Variables - Attributes |
RMCLink Component | RMC70, RMC150, and RMC200 Register Data Types
