RMCLink Address Map for the RMC200 |
When using RMCLink, the addresses of the registers in the RMC200 are specified with a File number and an Element number. The file and element used by RMCLink for the RMC200 are the same as the addressing convention used by RMCTools. Use the RMCTools software and RMCTools help to find the correct File and Element values for the data items in the RMC200. For other RMCs, refer to the RMCLink Address Map topic.
In Visual Basic, Visual C++, and the .NET languages, the File Constants (in the help Contents, see the Enumeration Types topic for the language you are using) can be used in the File parameter of the Read and Write methods to make the code more readable. The File Constants cannot be used in scripting or VBA.
The following table lists the files sections in the RMC200 and the associated enumerated file constants.
File |
File Constant |
7 |
fn200ControllerInfo |
Basic controller read-only information |
8 |
fn200IndDataValues |
Indirect Data Map Values |
12 |
fn200IndDataMap |
Indirect Data Map Definition |
16 |
fn200CommandArea |
Command Registers for all axes |
18 |
fn200ControllerRegs |
Controller Status/Configuration |
20 |
fn200DiscreteIO |
Discrete I/O |
21 |
fn200TaskManager |
Task Configuration |
22 |
fn200PlotManager |
Plot Layout |
23 |
fn200ImageArea |
Image Upload/Download Area |
24 |
fn200AxisAssignActive |
Axis Definitions (active) |
25 |
fn200AxisAssignNew |
Axis Definitions (new) |
26 |
fn200ModuleDefs |
Module Definitions |
112 |
fn200CommConfig |
Communication Configuration |
113 |
fn200AddressMapDF1 |
DF1 Address Map |
114 |
fn200AddressMapMB |
Modbus Address Map |
115 |
fn200AddressMapFINS |
FINS Address Map |
116 |
fn200AddressMapPN |
PROFINET Data Record Address Map |
128- 143 |
fn200ModuleBase, fn200ModuleSlot0PS, fn200ModuleSlot1CPU, fn200ModuleSlot2, fn200ModuleSlot3, etc. |
Module Status/Configuration |
192- 255 |
fn200TaskStatus0, |
Tasks 0-63 Status Note: In .NET applications, TaskStatus is StatusTask. |
256- 383 |
fn200StatusAxis0, fn200StatusAxis1, etc. |
Axis 0-127 Status Registers |
384- 511 |
fn200ParameterAxis0, fn200ParameterAxis1, etc. |
Axis 0-127 Parameter Registers |
512- 575 |
fn200Plot0CfgSts, fn200Plot2CfgSts, etc. |
Plot 0-63 Configuration |
576- 639 |
fn200Plot0DynUA, fn200Plot1DynUA, etc. |
Plot 0-63 Dynamic Plot Upload Area |
640- 703 |
fn200Plot0StaticUA, |
Plot Static Upload Area, Plots 0-3, Sample Sets 0-3 |
1024 |
fn200VarCurValues |
Variables - Current Values |
1280 |
fn200VarInitValues |
Variables - Initial Values |
1536 |
fn200VarAttributes |
Variables - Attributes |
RMCLink Component | RMC70, RMC150, and RMC200 Register Data Types
