When using RMCLink, the addresses of the registers in the RMC150 are
specified with a File number and
an Element number. Use this address
map to find the correct File and
Element values for the data items
in the RMC150. Notice that the file
and element used by RMCLink for
the RMC150 are the same as the addressing convention used by RMCTools.
For other RMCs, refer to the RMCLink
Address Map topic.
In Visual Basic, Visual C++, and the .NET languages, the File Constants
(in the help Contents, see the Enumeration
Types book for the language you are using) can be used in the File
parameter of the Read and Write methods to make the code more readable.
The File Constants cannot be used in scripting or VBA.
Refer to the RMCTools help for details on how to use the various registers
in the RMC150.
File
File Constant
Description
7
fn150ControllerInfo
Basic controller read-only information
8-23
fn150StatusAxis0,
fn150StatusAxis1, etc.
Axis 0-15 Status Registers
Each file 8-23 represents one axis. File 8 is Axis 0, file 9 is Axis 1, etc.
Element
Register Name
Registers 0 - 4: Common
All Axes
Status Bits
1
Error Bits
2
Last Error Number
4
Read Response
Registers 8 - 15: Primary Input
Position Axes
Velocity Axes
Single Input Pressure/Force Axes
Dual Input Force Axes
8
Actual Position
Actual Pressure/Force
Actual Differential Force
9
Actual Velocity
Actual Velocity
Actual Pressure/Force Rate
Actual Differential Force Rate
10
Actual Acceleration
Actual Acceleration
Actual Force A
11
Counts/Voltage
Voltage
Voltage
Voltage A
12
Raw Counts
Raw Counts
Raw Counts
Raw Counts A
13
Actual Force B
14
Voltage B
15
Raw Counts B
Registers 18 - 20: Home/Latch
Quadrature Axes
18
H/L Status Bits
19
Latched Position 0
20
Latched Position 1
Registers 23 - 30: Secondary Input
23
24
25
Actual Force A
26
Voltage
Voltage A
27
Raw Counts
Raw Counts A
28
Actual Force B
29
Voltage B
30
Raw Counts B
Register 33: Output
Analog Axes
33
Control Output
Registers 35-43: Primary Control
Position Axes
Velocity Axes
35
Position Error
Pressure/Force Error
36
Velocity Error
Velocity Error
37
Proportional Term
Velocity Integral term
Pressure/Force Proportional Term
38
Integral Term
Pressure/Force Integral Term
39
Differential Term
Velocity Proportional Term
Pressure/Force Differential Term
40
Pressure/Force Feed Forward Term
41
Velocity Feed Forward Term
Pressure/Force Rate Feed Forward Term
42
Acceleration Feed Forward Term
43
PFID Output
PFID Output
PFID Output
Registers 44-50: Secondary Control
Servo Pressure/Force Axes
44
45
Reserved
46
47
Reserved
48
49
50
Registers 53-57: Primary Target
Position Axes
53
Target Position
54
Target Velocity
55
Target Acceleration
56
Command Position
57
Command Velocity
Registers 60-61: Secondary Target
Pressure/Force Axes
60
Target Pressure/Force
61
Command Pressure/Force
24-39
fn150ParameterAxis0,
fn150ParameterAxis1, etc.
Axis 0-15 Parameter Registers
Each file 24-39 represents one axis. File 24 is Axis 0, file 25 is Axis 1, etc.
Element
Register Name
Registers 0 - 13: Primary Feedback
Position Axes
Velocity Axes
Single-Input Pressure/Force Axes
Dual-Input Force Axes
Position Scale
Position Scale
Pressure/Force Scale
Force A Scale
1
Position Offset
Velocity Offset
Pressure/Force Offset
Force A Offset
2
Actual Position Filter
Velocity Deadband
Force B Scale
3
Actual Velocity Filter
Force B Offset
4
Actual Acceleration Filter
Actual Pressure/Force Filter
5
Stop Threshold
Stop Threshold
Actual Pressure/Force Rate Filter
6
Noise Error Rate
Noise Error Rate
Noise Error Rate
Noise Error Rate
9
Bit 0:
Linear/Rotary
Linear/Rotary
Linear/Rotary
Linear/Rotary
Bit 1:
Absolute/Incremental
MDT/SSI Transducer
Analog Transducer
10
Bits 0-2: MDT Type
Bit 8: MDT/SSI
Bit 9: SSI Format (Binary/Gray)
Bits 10-11: SSI Clock Rate
Bits 12-17: SSI Data Bits
Bits 0-2: Input Range
11
Count Offset
12
Position Unwind
Registers 18-28: Secondary Feedback
18
Force A Scale
19
Force A Offset
20
Force B Scale
21
Force B Offset
22
23
24
Noise Error Rate
Noise Error Rate
27
Bit 0:
Linear/Rotary
Linear/Rotary
Bit 1:
Analog Transducer
28
Registers 32-34: Output
Analog
32
Output Limit
33
Output Bias
34
Bit 0: Invert Output Polarity
Bit 1: Reserved
Bit 2: Enable Output Behavior
Bit 3: Fault Input Polarity
Bit 4: Limits Polarity
Registers 38-42: Final Output Stage
Servo
38
Output Scale
39
Output Filter
40
Directional Gain Ratio
41
Deadband Tolerance
42
Output Deadband
Registers 56-67: Primary Control
Servo Position Axes
Servo Velocity Axes
56
In Position Tolerance
At Pressure/Force Tolerance
57
Position Error Tolerance
Pressure/Force Error Tolerance
58
At Velocity Tolerance
59
Velocity Error Tolerance
60
Bits 0-3:
Integrator Mode
Integrator Mode
Integrator Mode
61
Position Proportional Gain
Velocity Integral Gain
Pressure/Force Proportional Gain
62
Position Integral Gain
Pressure/Force Integral Gain
63
Position Differential Gain
Velocity Proportional Gain
Pressure/Force Differential Gain
64
65
66
67
Integrator Limit
Integrator Limit
Pressure/Force Integrator Limit
Registers 76-85: Secondary Control
76
77
80
Bits 5-6:
Pressure/Force Orientation
81
82
83
84
85
Registers 92-93: Position Target
Position
92
Positive Travel Limit
93
Negative Travel Limit
Registers 100-101: Pressure/Force Target
Position
100
Positive Pressure/Force Limit
101
Negative Pressure/Force Limit
Registers 106-113: Halts
All Axes
106/0-2
Bits 0-2:
Auto Stop Following Error
106/3-5
Bits 3-5:
Reserved
106/6-8
Bits 6-8:
Auto Stop Output Saturated
106/9-11
Bits 9-11:
Auto Stop Fault Input
106/12-14
Bits 12-14:
Auto Stop Positive Limit Input
106/15-17
Bits 15-17:
Auto Stop Negative Limit Input
106/18-20
Bits 18-20:
Auto Stop No Transducer
106/21-23
Bits 21-23:
Auto Stop Transducer Overflow
107/0-2
Bits 0-2:
Auto Stop Noise Error
107/3-5
Bits 3-5:
Auto Stop Positive Overtravel
107/6-8
Bits 6-8:
Auto Stop Negative Overtravel
107/9-11
Bits 9-11:
Auto Stop Command Error
107/12-14
Bits 12-14:
Auto Stop Command Modified
107/15-17
Bits 15-17:
Auto Stop Configuration Error
107/18-20
Bits 18-20:
Auto Stop Runtime Error
108/6-8
Bits 6-8:
Auto Stop No Transducer (Secondary)
108/9-11
Bits 9-11:
Auto Stop Transducer Overflow (Secondary)
108/12-14
Bits 12-14:
Auto Stop Noise Error (Secondary)
108/15-17
Bits 15-17:
Auto Stop Following Error (Secondary)
110
Closed Loop Halt Deceleration
111
Open Loop Halt Ramp
112
Halt Group Number
Registers 116-119: Simulation
All Axes
116
Bit 0: Simulate Mode
117
System Gain (Simulate Mode)
118
Natural Frequency (Simulate Mode)
119
Damping Factor (Simulate Mode)
40
fn150CommandArea
Command Area
Element
Register Name
0-9
Axis 0 Command Registers
Axis 0 Command
1
Axis 0 Parameter 1
2
Axis 0 Parameter 2
3
Axis 0 Parameter 3
4
Axis 0 Parameter 4
5
Axis 0 Parameter 5
6
Axis 0 Parameter 6
7
Axis 0 Parameter 7
8
Axis 0 Parameter 8
9
Axis 0 Parameter 9
10-19
Axis 1 Command Registers
20-29
Axis 2 Command Registers
30-39
Axis 3 Command Registers
40-49
Axis 4 Command Registers
50-59
Axis 5 Command Registers
60-69
Axis 6 Command Registers
70-79
Axis 7 Command Registers
80-89
Axis 8 Command Registers
90-99
Axis 9 Command Registers
100-109
Axis 10 Command Registers
110-119
Axis 11 Command Registers
120-129
Axis 12 Command Registers
130-139
Axis 13 Command Registers
140-149
Axis 14 Command Registers
150-159
Axis 15 Command Registers
41
fn150IndDataMap
Indirect Data Map
Element
Register Name
0-127
Indirect Data Map
Note:
The Indirect Data Map (file 41) contains the addresses of the referenced registers, not the data. Do not read or write to these registers when accessing the Indirect Data values via a PLC. See the Indirect Data registers (file 18, elements 0-31).
42
fn150IndDataValues
Indirect Data
Element
Register Name
0-127
Indirect Data Values
Note:
These registers (file 42) are the registers that should be accessed at runtime by a PLC when reading or writing the Indirect Data.
43
fn150AxisAssign
Axis Assignment
44
fn150ControllerRegs
Controller Parameters/Status
Element
Register Name
Notes
Loop Time, Set
Read-Only
1
Loop Time, Requested
Do not use this register!
2
Loop Time, Length of Last Used
Read-Only
3
Loop Time, Length of Maximum Used
R/W, but can only be set to 0.
4
Number of Tasks Allocated (0-10, default = 2)
default = 2
5
PreScan Table Enabled? (0=false, 1= true)
default = 1
6
Stop All Tasks on Any Axis Halt? (0=false, 1= true)
default = 1
7
Controller Status Register
Bit 0: RUN/PROGRAM (0=PROGRAM, 1= RUN)
Bit 1: Controller Enabled
Bit 2: First Scan
8
Startup Mode (0=PROGRAM(default), 1-RUN)
9
RUN/PROGRAM Input (0 = None, 1 = %IX1.0, 2 = %IX1.1)
10-31
Reserved
45
fn150CommConfig
Communication Configuration
Element
Description
Notes
0-7
Reserved
8
MAC Address (bytes 0-3, big Endian) (for 00-50-A0-B1-23-45, this would be 0x0050A0B1)
Read-Only
9
MAC Address (bytes 4-5, big Endian in upper 16 bits) (for 00-50-A0-B1-23-45, this would be 0x23450000)
Read-Only
10
Ethernet Status Bits:
Bit 0: Link Established
Bit 1: 1=100Mbps, 0=10Mbps
Bit 2: 1=FDX, 0=HDX
Bit 4-7:Current IP Address State
0=Static Method, but an unusable address is assigned (e.g. 0x00000000)
1=IP Address assigned and in use
2=IP Address assigned, but disabled due to duplicate detected
3=IP Address assigned, but still doing Address Collision Detection
4=BOOTP: Still querying, no address yet assigned
5=DHCP: Still querying, no address yet assigned
Read-Only
11
Ethernet Configuration Bits:
Bit 0: 0=Use Auto-Negotiation, 1=Disable Auto-Negotiation (use bits 1 and 2)
Bit 1: If AN disabled, 0=10Mbps, 1=100Mbps
Bit 2: If AN disabled, 0=HDX, 1=FDX
Bit 3-4: IP Address Assignment Mode
0=Statically Assigned
1=BOOTP
2=DHCP
12
IP Address
13
Subnet Mask (0=use standard network masks)
14
Default Gateway (0=none)
15
DHCP (or BOOTP) server IP Address
16
DHCP Lease Start (seconds since powerup)
17
DHCP Lease End (seconds since powerup)
47
fn150DiscreteIO
Discrete I/O
n = RMC slot number (0-5)
Element
Register Name
0+n
Outputs for slot n
6+n
Inputs for slot n
12+n
Output to Off in PROGRAM mode for slot n
18+n
Output to On in PROGRAM mode for slot n
24+n
Output to Off in FAULT mode for slot n
30+n
Output to On in FAULT mode for slot n
36+n
Forced Off for Outputs in slot n
42+n
Forced On for Outputs in slot n
48+n
Forced Off for Inputs in slot n
54+n
Forced On for Inputs in slot n
Note:
All the registers in file 23 are of the DWORD data type.
48
fn150TaskStatus
Task Status/Configuration
Element
Register Name
0 - 15
Task 0 Status
State
Bit 0: Running?
Bit 1: Allocated?
1
Current Step
Bits 0-11: Step Number
Bits 12-23: Program Number
2
Current Axis (0..3)
3-15
Reserved
16-31
Task 1 Status (same as Task 0 Status)
32-47
Task 2 Status (same as Task 0 Status)
48-63
Task 3 Status (same as Task 0 Status)
49
fn150AxisNames
Axis Names
56-59
fn150VarCurValues
Variables - Current Values
Element
Register Name
0-1023
Variables 0 to 1023 - Current Values
72-75
fn150VarInitValues
Variables - Initial Values
Element
Register Name
0-1023
Variables 0 to 1023 - Initial Values
88
fn150VarAttributes
Variables - Attributes
94
fn150ImageArea
Image Area
95
fn150PlotSchema
Plot Layout
Element
Access
Data Type
Register Description
Read/Write
UDINT
Current Plot Layout
Bits 0-7: Plots (1-8)
Bits 8-15: Sample Sets per Plot (1-16)
Bits 16-23: Reserved
1
Read Only
UDINT
Maximum Plots (8)
2
Read Only
UDINT
Maximum Samples (16)
3
Read Only
UDINT
Maximum Samples at Once (128)
4
Read Only
UDINT
Maximum Elements (12,582,912)
5
UDINT
Reserved
6
UDINT
Reserved
7
UDINT
Reserved
96
fn150Plot0CfgSts
Plot 0 Configuration
Element
Access
Data Type
do not access directly
UDINT
Plot 0 Flags (should not be accessed directly)
Bit 0: Reserved
Bit 1: Trigger (WO)
Bit 2: Re-arm (WO)
Bit 3: Read Active (RO)
1
Read/Write
UDINT
Plot 0 Samples (e.g. 1000)
2
Read/Write
REAL
Plot 0 Samples Period (seconds)
3
Read/Write
DINT
Plot 0 Axis Owner (0-3, -1 = none)
4
Read/Write
DINT
Plot 0 Trigger Position (%, 0-100, -1 = auto re-arm)
5
Read/Write
UDINT
Plot 0 Trigger Type
Bits 0-7: Type (0=none, 1=motion command)
Bits 8-23: Depends on trigger type
Motion Commands:
Bits 8-11: Axis 0-3 Bits, if all zero, then use Axis Owner
Bits 12-23: Reaserved
6
Reserved
7
Reserved
8
Read Only
REAL
Plot 0 ID
9
Read Only
REAL
Plot 0 State (0 = not triggered, 1 = capturing, 2 = complete)
10
Read Only
REAL
Plot 0 Captured Samples (relative to sample 0), state > 0
11
Read Only
REAL
Plot 0 Sample Time (control loops), state > 0
12
Read Only
REAL
Plot 0 Trigger Time (control loops), state > 0
13
Read Only
REAL
Plot 0 Trigger Sample (relative to sample 0)
12-15
Reserved
16-31
Addresses of Plot Data Sets 0-15
Bits 0-11: Element
Bits 12-23: File
97
fn150Plot1CfgSts
Plot 1 Configuration - Identical to file 96
98
fn150Plot2CfgSts
Plot 2 Configuration - Identical to file 96
99
fn150Plot3CfgSts
Plot 3 Configuration - Identical to file 96
100
fn150Plot4CfgSts
Plot 4 Configuration - Identical to file 96
101
fn150Plot5CfgSts
Plot 5 Configuration - Identical to file 96
102
fn150Plot6CfgSts
Plot 6 Configuration - Identical to file 96
103
fn150Plot7CfgSts
Plot 7 Configuration - Identical to file 96
104
fn150Plot0DynUA
Plot 0 Dynamic Plot Upload Area
Element
Access
Data Type
Read/Write
UDINT
Bits 0-3: Upload Mode
1 = triggered
2 = continuous
3 = continuous, always newest
Bits 4-7: Upload Status (Read Only)
0 = normal
1 = plot state mismatches upload mode
2 = data overran (mode 2 only)
1
Read/Write
UDINT
Requested Read Samples
2
Read/Write
UDINT
Current Index
3
Read Only
UDINT
Plot ID
4
Read Only
UDINT
Samples Uploaded
5-255
Read Only
Plot Data
105
fn150Plot1DynUA
Plot 1 Dynamic Plot Upload Area - Identical to file 104
106
fn150Plot2DynUA
Plot 2 Dynamic Plot Upload Area - Identical to file 104
107
fn150Plot3DynUA
Plot 3 Dynamic Plot Upload Area - Identical to file 104
108
fn150Plot4DynUA
Plot 4 Dynamic Plot Upload Area - Identical to file 104
109
fn150Plot5DynUA
Plot 5 Dynamic Plot Upload Area - Identical to file 104
110
fn150Plot6DynUA
Plot 6 Dynamic Plot Upload Area - Identical to file 104
111
fn150Plot7DynUA
Plot 7 Dynamic Plot Upload Area - Identical to file 104
112-
143
fn150Plot0StaticUA,
fn150Plot1StaticUA, etc.
Static Plot Upload Area - Plots 0-7, Sample Sets 0-3
File
Elements
Description
112
0-4095
Plot 0, Sample Set 0, Samples 0-4095
113
0-4095
Plot 0, Sample Set 1, Samples 0-4095
114
0-4095
Plot 0, Sample Set 2, Samples 0-4095
115
0-4095
Plot 0, Sample Set 3, Samples 0-4095
116
0-4095
Plot 1, Sample Set 0, Samples 0-4095
117
0-4095
Plot 1, Sample Set 1, Samples 0-4095
118
0-4095
Plot 1, Sample Set 2, Samples 0-4095
119
0-4095
Plot 1, Sample Set 3, Samples 0-4095
120
0-4095
Plot 2, Sample Set 0, Samples 0-4095
121
0-4095
Plot 2, Sample Set 1, Samples 0-4095
122
0-4095
Plot 2, Sample Set 2, Samples 0-4095
123
0-4095
Plot 2, Sample Set 3, Samples 0-4095
124
0-4095
Plot 3, Sample Set 0, Samples 0-4095
125
0-4095
Plot 3, Sample Set 1, Samples 0-4095
126
0-4095
Plot 3, Sample Set 2, Samples 0-4095
127
0-4095
Plot 3, Sample Set 3, Samples 0-4095
128
0-4095
Plot 4, Sample Set 0, Samples 0-4095
129
0-4095
Plot 4, Sample Set 1, Samples 0-4095
130
0-4095
Plot 4, Sample Set 2, Samples 0-4095
131
0-4095
Plot 4, Sample Set 3, Samples 0-4095
132
0-4095
Plot 5, Sample Set 0, Samples 0-4095
133
0-4095
Plot 5, Sample Set 1, Samples 0-4095
134
0-4095
Plot 5, Sample Set 2, Samples 0-4095
135
0-4095
Plot 5, Sample Set 3, Samples 0-4095
136
0-4095
Plot 6, Sample Set 0, Samples 0-4095
137
0-4095
Plot 6, Sample Set 1, Samples 0-4095
138
0-4095
Plot 6, Sample Set 2, Samples 0-4095
139
0-4095
Plot 6, Sample Set 3, Samples 0-4095
140
0-4095
Plot 7, Sample Set 0, Samples 0-4095
141
0-4095
Plot 7, Sample Set 1, Samples 0-4095
142
0-4095
Plot 7, Sample Set 2, Samples 0-4095
143
0-4095
Plot 7, Sample Set 3, Samples 0-4095
144
fn150Slot0Settings
Slot 0 Settings
145
fn150Slot1Settings
Slot 1 Settings
146
fn150Slot2Settings
Slot 2 Settings
147
fn150Slot3Settings
Slot 3 Settings
148
fn150Slot4Settings
Slot 4 Settings
149
fn150Slot5Settings
Slot 5 Settings
