Handling RMCLink.Interop .NET Assembly Errors |
The RMCLink object uses .NET exceptions to report unexpected errors. Each RMCLink method's documentation lists the exceptions that it may throw. It should be pointed out that while many of these exceptions can be avoided while the program is being developed (e.g. ArgumentOutOfRangeException), some can simply not be avoided at runtime. For example, if the communication cable is disconnected while a read or write is in progress, the communication will fail unexpectedly. Therefore, it is important that applications using RMCLink handle, at a minimum, the ConnectionNotMadeException and ReadWriteFailedException, and in multithreaded applications, CancelledException as well.
As is recommended for all .NET programming, exceptions should be caught specifically by type. You can then use the Message property to determine the root cause of the exception. For example, after catching a ConnectionNotMadeException, the Message property might tell you that the serial port is in use by another application.
The following code example illustrates the proper use of .NET exceptions with the RMCLink.Interop assembly.
Visual Basic .NET |
Module Module1
Try
Console.WriteLine("Connecting...")
Try
Console.WriteLine("Reading Axis 0 Actual Position...")
rmc.ReadFFile(FileNumber70.fn70StatusAxis0, 8, data, 0, 1)
Console.WriteLine(String.Format(" ActPos: {0:F3}", data(0)))
Console.WriteLine("Done")
Finally
End Try
Catch ex As ConnectionNotMadeException
Console.WriteLine("Unable to connect to the controller. " & ex.Message)
Catch ex As ReadWriteFailedException
Console.WriteLine("Unable to read from the controller. " & ex.Message)
End Try
try
Console.WriteLine("Connecting...");
try
float[] data = new float[1];
Console.WriteLine("Reading Axis 0 Actual Position...");
rmc.ReadFFile((int)FileNumber70.fn70StatusAxis0, 8, data, 0, 1);
Console.WriteLine(String.Format(" ActPos: {0:F3}", data[0]));
Console.WriteLine("Done");
finally
catch (ConnectionNotMadeException e)
Console.WriteLine("Unable to connect to the controller. " + e.Message);
catch (ReadWriteFailedException e)
Console.WriteLine("Unable to read from the controller. " + e.Message);
try
Console::WriteLine("Connecting...");
try
Console::WriteLine("Reading Axis 0 Actual Position...");
rmc->ReadFFile((int)FileNumber70::fn70StatusAxis0, 8, data, 0, 1);
Console::WriteLine(String::Format(" ActPos: {0:F3}", data[0]));
Console::WriteLine("Done");
finally
catch (ConnectionNotMadeException^ e)
Console::WriteLine("Unable to connect to the controller. " + e->Message);
catch (ReadWriteFailedException^ e)
Console::WriteLine("Unable to read from the controller. " + e->Message);
