How to: Send RMC100 Commands |
One common task when controlling an RMC100 through the RMCLink component is to issue commands to one or more axes (see the online help in RMCWin for details on what commands are available and what they do).
Commands are issued by writing to the command files for each axis, which are numbered L8-L15 for axes 0-7 respectively. Each file consists of six (6) registers per axis. The last (sixth) register in each axis's command file is the command, and the first five registers are command parameters for that command. The meaning of the command parameters vary depending on the command selected by the first register.
Notice that on the RMC100, most commands are given as letters or symbols (for example, the "Go" command is "G", and the "Set Pressure" command is "^"). However, when writing to the command register for an axis, a number must be written. To find the number corresponding to a letter or symbol command, use the ASCII value of that letter or symbol, which can be found either by looking up the command in the RMCWin online help, where the number value will be listed, or you can use a language-specific method, if one is available, such as Visual Basic's Asc function (in Visual Basic, Asc("G") will return the numeric value for "G", 71).
When an outside source writes to the command files, each axis written to will run the command sent to it immediately. Notice that it is important that all axes that are to run their commands simultaneously must be written to in the same write. In order to allow this to work, writes that extend beyond the end of one command file continue in the next command file. Therefore, to issue commands to axes 0 and 1 at the same time, write 12 registers starting at L8:0.
Notice that a special command of NoOp (0) can be issued to have the axis ignore the command written to it. Therefore, to issue commands simultaneously to axes 0 and 2 at the same time, write 18 registers starting at L8:0, but make sure that the seven value (the one written to L9:0) is zero (0) so that only commands 0 and 2 act on their commands.
The following steps should be used to write a command to one or more axes in the RMC100:
Declare an array of 32-bit integer (long from C++, Long from VB5/6, Integer from VB.NET, int from C#) values. The length of the array should be rmc100CmdRegsPerAxis (6) times the number of axes you want to write to.
Initialize all values in the array. Set the sixth array element for each axis (element 5, 11, 17, etc. for axes 0, 1, 2, etc.) to the number of the command. Again, as described above, the ASCII value of letter or symbol commands must be used. So for the Go (G) command, use 71. Set the first five elements for each axis's command file to the five command parameters for that command. If the command uses less than all five command parameters, set the array element for that the extra parameters to zero (0).
For axes that you do not want to receive a command on this write, just use command number zero (0), and set all the command parameters for that command to zero (0) as well.
Call the WriteLFile method. The file parameters should be fn100CommandAxisN (8+N), where N is the first axis you want to issue a command to. The element parameter should be zero (0). The count parameter should match the length of the data array declared above, and the data parameter should be the array declared above.
Refer to the example below.
Reading from the command files is not meaningful; zeros will simply be returned for each register.
The acknowledge bit works as it normally does when used via RMCLink.
The following code example illustrates sending commands to an RMC100.
Set rmc = srv.CreateEthernetLink(dtRMC100, "192.168.0.28")
' Issue a Go (G) command to Axis 0 (registers L8:0-5).
Dim data(5) As Long
data(0) = &H81 ' Mode (S-Curves, Accel/Decel Mode 1)
data(1) = 100 ' Acceleration Rate (100 in/s/s)
data(2) = 100 ' Deceleration Rate (100 in/s/s)
data(3) = 10000 ' Requested Speed (10 in/s)
data(4) = 4000 ' Requested Position (4 in)
data(5) = Asc("G") ' Go (G) command
rmc.WriteLFile fn100CommandAxis0, 0, rmc100CmdRegsPerAxis, data
Visual Basic .NET |
Dim rmc As RMCLink = RMCLink.CreateEthernetLink(DeviceType.RMC100, "192.168.0.10")
Dim cmd() As Integer = new Integer(5) {}
cmd(0) = &H81 ' Mode (S-Curves, Accel/Decel Mode 1)
cmd(1) = 100 ' Acceleration Rate (100 in/s/s)
cmd(2) = 100 ' Deceleration Rate (100 in/s/s)
cmd(3) = 10000 ' Requested Speed (10 in/s)
cmd(4) = 4000 ' Requested Position (4 in)
cmd(5) = Asc("G") ' Go (G) Command
rmc.WriteLFile(FileNumber100.fn100CommandAxis0,0,cmd,0, _
Constants100.rmc100CmdRegsPerAxis);
// Create the object itself.
RMCLink rmc = RMCLink.CreateEthernetLink(DeviceType.RMC100, "192.168.0.10");
// Issue a Go (G) command to Axis 0 (registers L8:0-5).
int[] cmd = new int[6];
cmd[0] = 0x0081; // Mode (S-Curves, Accel/Decel Mode 1)
cmd[1] = 100; // Acceleration Rate (100 in/s/s)
cmd[2] = 100; // Deceleration Rate (100 in/s/s)
cmd[3] = 10000; // Requested Speed (10 in/s)
cmd[4] = 4000; // Requested Position (4 in)
cmd[5] = (int)'G'; // Go (G) Command
CRMCLink* pRMC = CRMCLink::CreateEthernetLink(CRMCLink::dtRMC100, _T("192.168.0.28"));
long alCmd[6];
alCmd[0] = 0x0081; // Mode (S-Curves, Accel/Decel Mode 1)
alCmd[1] = 100; // Acceleration Rate (100 in/s/s)
alCmd[2] = 100; // Deceleration Rate (100 in/s/s)
alCmd[3] = 10000; // Requested Speed (10 in/s)
alCmd[4] = 4000; // Requested Position (4 in)
alCmd[5] = 'G'; // Go (G) command
hr = pRMC->WriteLFile(CRMCLink::fn100CommandAxis0, 0,
CRMCLink::rmc100CmdRegsPerAxis, alCmd);
printf("Command successfully written.");
C++/CLI |
array<int>^ cmd = gcnew array<int>(6);
rmc->WriteLFile(FileNumber100.fn100CommandAxis0,0,cmd,0,
Constants100::rmc100CmdRegsPerAxis);
Dim srv, rmc
' NOTE: VBScript does not support enumerations, so we use the literal value (dtRMC100=1).
Set rmc = srv.CreateEthernetLink(1, "192.168.0.28")
Dim data(5)
data(5) = ASC("G") ' Go (G) command
rmc.WriteLFile 8,0,6,data
// NOTE: JScript does not support enumerations, so we use the literal value (dtRMC100=1).
var rmc = srv.CreateEthernetLink(1, "192.168.0.28");
var data = new Array(6);
data[0] = 0x0081; // Mode (S-Curves, Accel/Decel Mode 1)
data[1] = 100; // Acceleration Rate (100 in/s/s)
data[2] = 100; // Deceleration Rate (100 in/s/s)
data[3] = 10000; // Requested Speed (10 in/s)
data[4] = 4000; // Requested Position (4 in)
data[5] = 71; // Go (G) command
rmc.WriteLFile(8,0,6,data);
How Do I Overview | RMCLink Component
