CRMCLink::enumRMCLINKERRORS Enumeration |
These constants represent the values of the COM exceptions that can be thrown by the RMCLink COM component.
RMCLINK_E_ALREADYLOCKED = 0x800A03E9 |
Internal RMCLink locking error. |
RMCLINK_E_DISCONNECTING = 0x800A03EA |
RMCLINK_E_BADTYPE = 0x800A03EB |
Invalid type passed in for write data. |
RMCLINK_E_BADLEN = 0x800A03EC |
Array length of write data does not match count parameter. |
RMCLINK_E_DISCONNECTED = 0x800A03ED |
RMCLINK_E_ALREADY_CONN = 0x800A03EE |
The link was already connected. |
RMCLINK_E_ALREADY_DISC = 0x800A03EF |
The link was already disconnected. |
RMCLINK_E_SOCK_INTERNAL = 0x800A03F0 |
RMCLINK_E_SOCK_CONN_FAIL = 0x800A03F1 |
Unable to connect over TCP/IP to requested device. |
RMCLINK_E_CANCELLED = 0x800A03F2 |
RMCLINK_E_TIMEOUT = 0x800A03F3 |
RMCLINK_E_SOCK_HOSTNAME_NOTIP = 0x800A03F4 |
Host name did not resolve to an IPv4 address. |
RMCLINK_E_SOCK_HOSTNAME_FAIL = 0x800A03F5 |
Host name did not resolve. |
RMCLINK_E_SOCK_GRACEFUL_CLOSE = 0x800A03F6 |
RMCLINK_E_SOCK_ERROR_RD = 0x800A03F7 |
RMCLINK_E_SOCK_INV_RD_LEN = 0x800A03F8 |
RMCLINK_E_SOCK_ERROR_WR = 0x800A03F9 |
RMCLINK_E_SOCK_INV_WR_LEN = 0x800A03FA |
RMCLINK_E_PORT_ACCESS_DENIED = 0x800A03FB |
Access to serial port denied. Verify not in use by another application. |
RMCLINK_E_PORT_NOT_FOUND = 0x800A03FC |
Serial port not found. |
RMCLINK_E_CE_IOE = 0x800A03FD |
Serial IOE error. |
RMCLINK_E_CE_FRAME = 0x800A03FE |
Serial framing error. |
RMCLINK_E_CE_BREAK = 0x800A03FF |
Serial Break error. |
RMCLINK_E_CE_OVERRUN = 0x800A0400 |
Serial overrun. |
RMCLINK_E_CE_RXOVER = 0x800A0401 |
Serial receive overrun. |
RMCLINK_E_CE_RXPARITY = 0x800A0402 |
Serial parity error. |
RMCLINK_E_CE_TXFULL = 0x800A0403 |
Serial transmitter full. |
RMCLINK_E_CONN_BROKEN = 0x800A0404 |
RMCLINK_E_PARTIAL_WRITE = 0x800A0405 |
RMCLINK_E_READ_ONLY = 0x800A0406 |
Attempt to write to read-only registers. |
RMCLINK_E_PRIVATE_RANGE = 0x800A0407 |
Attempt to read/write from private registers. |
RMCLINK_E_BAD_ADDRESS = 0x800A0408 |
RMCLINK_E_SOCK_HOSTNAME_INV = 0x800A0409 |
Invalid host name format. |
RMCLINK_E_WRONG_CONTROLLER = 0x800A040A |
Remote device is the wrong controller type. |
RMCLINK_E_NOT_SUPPORTED = 0x800A040B |
Operation not supported on this controller type. |
RMCLINK_E_BLDIMG_TIMEOUT = 0x800A040C |
Timeout waiting for image to be built. |
RMCLINK_E_BLDIMG_ERROR = 0x800A040D |
Controller unable to build image. |
RMCLINK_E_BLDIMG_STATE = 0x800A040E |
Unexpected state encountered while building image. |
RMCLINK_E_UL_FAILED = 0x800A040F |
Unable to upload completed image. |
RMCLINK_E_DL_CANT_RESET = 0x800A0410 |
Unable to reset Image Area for download. |
RMCLINK_E_DL_FAILED = 0x800A0411 |
Unable to download controller image. |
RMCLINK_E_BAD_IMAGE = 0x800A0412 |
Image format is invalid. |
RMCLINK_E_APPLY_TIMEOUT = 0x800A0413 |
Timeout applying downloaded image. |
RMCLINK_E_APPLY_STATE = 0x800A0414 |
Unexpected state encountered while applying image. |
RMCLINK_E_APPLY_RSTREQ = 0x800A0415 |
Image not applied because restart required. |
RMCLINK_E_APPLY_FLASH = 0x800A0416 |
Error writing to flash memory while applying image. |
RMCLINK_E_APPLY_NOTINRUN = 0x800A0417 |
Image cannot be applied without restart while in RUN mode. |
RMCLINK_E_APPLY_WRONGHW = 0x800A0418 |
Image not applied because of hardware mismatch. |
RMCLINK_E_USB_NO_DRIVERS = 0x800A0419 |
Unable to access RMC USB driver. Please ensure that the driver has been properly installed. |
RMCLINK_E_USB_DEV_NOT_FOUND = 0x800A041A |
The controller with the specified DeviceId was not found on any USB port. |
RMCLINK_E_USB_SETTIMEOUT = 0x800A041B |
RMCLINK_E_USB_TXRXCLEAR = 0x800A041C |
RMCLINK_E_USB_OP_ABORT = 0x800A041D |
RMCLINK_E_USB_DISCONNECT = 0x800A041E |
RMCLINK_E_USB_UNK_FAILURE = 0x800A041F |
The requested RMC is plugged into a USB port, but cannot be accessed. Ensure that no other applications are using this RMC. If the problem persists, try unplugging and re-plugging the USB cable to this controller and retry. |
RMCLINK_E_USB_IN_USE = 0x800A0420 |
RMCLINK_E_USB_NO_SETUPAPI = 0x800A0421 |
Unable to access operating system functionality for connecting to USB devices. |
RMCLINK_E_FILE_NOT_FOUND = 0x800A0422 |
Unable the find the specified file. |
RMCLINK_E_PATH_NOT_FOUND = 0x800A0423 |
Unable the find the specified file path. |
RMCLINK_E_ACCESS_DENIED = 0x800A0424 |
Access denied to the file or path. |
RMCLINK_E_DRIVE_NOT_READY = 0x800A0425 |
Removable drive not ready. |
RMCLINK_E_BLDIMG_NOT_ALLOWED = 0x800A0426 |
Controller unable to build upload image because copy protection is enabled. |
