RMCLink C++ Wrapper Class CRMCLink::enumCONSTANTS100 Enumeration |
Miscellaneous constants for use when communicating with the RMC100. These are typically used when computing file, element, of count parameters.
rmc100StsRegsPerAxis = 10 |
Number of registers in each axis's fn100StatusAxisn file. This can be used when reading multiple axes' status. |
rmc100CmdRegsPerAxis = 6 |
Number of registers in each axis's fn100CommandAxisn file. This can be used when writing commands to multiple axes. |
rmc100ParamRegsPerAxis = 16 |
Number of registers in each axis's fn100ParameterAxisn file. This can be used when reading or writing parameters on multiple axes. |
rmc100RegsPerStep = 8 |
Number of registers per step in the fn100StepTable file. This can be used to calculate the element parameter in read and write methods. |
rmc100RegsPerI2EInput= 8 |
Number of registers per input line in the Input-to-Event table in the fn100I2ERisingEdges and fn100I2EFallingEdges files. This can be used to calculate the element parameter in read and write methods. |
rmc100RegsPerProfile = 4 |
Number of registers per profile in the fn100ProfileTable file. This can be used to calculate the element parameter in read and write methods. |
rmc100RegsPerPlotFile = 1024 |
Number of registers in each fn100PlotAxisnSetnfile. |
rmc100MaxAxes = 8 |
Number of axes for which registers files are allocated. |
rmc100PlotFilesPerAxis = 6 |
Number of plot files per axis. This can be used to compute the file to use to read up plot data for a particular axis. |
rmc100PTPrecision = 0 |
Extra Precision Plot Type. This can be used when reading from or writing to the fn100PlotTypes file. |
rmc100PTCommands = 1 |
Command Plot Type. This can be used when reading from or writing to the fn100PlotTypes file. |
rmc100PTEvents = 2 |
Event Step Plot Type. This can be used when reading from or writing to the fn100PlotTypes file. |
rmc100PTCounts = 3 |
Raw Counts Plot Type. This can be used when reading from or writing to the fn100PlotTypes file. |
