RMCLink C++ Wrapper Class CRMCLink::ReadBit Method |
Reads a single bit from an integer (L) register in the RMC. ReadBit is typically used to read the value of a status bit in the RMC.
HRESULT ReadBit( UINT file, UINT element, UINT bit, bool& value ); |
File number of the register with the bit to be read. See the RMCLink Register Reference for details.
Element number of the register with the bit to be read. See the RMCLink Register Reference for details.
bit
Number of the bit (0-31) to read in the register. Bits are numbered from least to most significant.
value
If the bit that was read was 1, then this parameter will return true, otherwise false.
E_OUTOFMEMORY |
E_INVALIDARG |
One of the file, element, or bit parameters are out of range. |
RMCLINK_E_DISCONNECTING |
RMCLINK_E_DISCONNECTED |
RMCLINK_E_SOCK_INTERNAL |
RMCLINK_E_CANCELLED |
RMCLINK_E_TIMEOUT |
RMCLINK_E_SOCK_ERROR_RD |
RMCLINK_E_SOCK_INV_RD_LEN |
RMCLINK_E_SOCK_ERROR_WR |
RMCLINK_E_SOCK_INV_WR_LEN |
RMCLINK_E_CE_IOE |
Serial IOE error. |
RMCLINK_E_CE_FRAME |
Serial framing error. |
RMCLINK_E_CE_BREAK |
Serial Break error. |
RMCLINK_E_CE_OVERRUN |
Serial overrun. |
RMCLINK_E_CE_RXOVER |
Serial receive overrun. |
RMCLINK_E_CE_RXPARITY |
Serial parity error. |
RMCLINK_E_CE_TXFULL |
Serial transmitter full. |
RMCLINK_E_CONN_BROKEN |
RMCLINK_E_PARTIAL_WRITE |
RMCLINK_E_BAD_ADDRESS |
RMCLINK_E_USB_SETTIMEOUT |
RMCLINK_E_USB_OP_ABORT |
RMCLINK_E_USB_DISCONNECT |
The following code example illustrates the use of the ReadBit method.
// Read bit 0 of L8:0 (Axis 0 In Position)
bool bInPosition;
hr = pRMC->ReadBit(CRMCLink::fn70StatusAxis0, 0, 0, bInPosition);
printf("In Position? %s\n", bInPosition ? "Yes" : "No");
