RMCLink C++ Wrapper Class CRMCLink::ReadBitField Method |
Reads a bit field (range of bits) from an integer (L) register in the RMC, and converts the binary value of the bits to a long integer. ReadBitField is typically used to read the value of a multiple-bit parameter in the RMC70, RMC150, or RMC200.
HRESULT ReadBitField( UINT file, UINT element, UINT fieldStart, UINT fieldLen, UINT& value ); |
File number of the register with the bit to be read. See the RMCLink Register Reference for details.
Element number of the register with the bit to be read. See the RMCLink Register Reference for details.
fieldStart
Number of the least significant bit (0-31) of the register's bit field. Bits are numbered from least to most significant.
fieldLen
Total number of bits in the bit field (1-32).
value
The value of the bit field is returned in this parameter.
E_OUTOFMEMORY |
E_INVALIDARG |
One of the file, element, fieldStart, or fieldLen parameters are out of range. |
RMCLINK_E_DISCONNECTING |
RMCLINK_E_DISCONNECTED |
RMCLINK_E_SOCK_INTERNAL |
RMCLINK_E_CANCELLED |
RMCLINK_E_TIMEOUT |
RMCLINK_E_SOCK_ERROR_RD |
RMCLINK_E_SOCK_INV_RD_LEN |
RMCLINK_E_SOCK_ERROR_WR |
RMCLINK_E_SOCK_INV_WR_LEN |
RMCLINK_E_CE_IOE |
Serial IOE error. |
RMCLINK_E_CE_FRAME |
Serial framing error. |
RMCLINK_E_CE_BREAK |
Serial Break error. |
RMCLINK_E_CE_OVERRUN |
Serial overrun. |
RMCLINK_E_CE_RXOVER |
Serial receive overrun. |
RMCLINK_E_CE_RXPARITY |
Serial parity error. |
RMCLINK_E_CE_TXFULL |
Serial transmitter full. |
RMCLINK_E_CONN_BROKEN |
RMCLINK_E_PARTIAL_WRITE |
RMCLINK_E_BAD_ADDRESS |
RMCLINK_E_USB_SETTIMEOUT |
RMCLINK_E_USB_OP_ABORT |
RMCLINK_E_USB_DISCONNECT |
The following code example illustrates the use of the ReadBitField method.
// Read bits 10-11 of L8:0 (Axis 0 Target State bits A and B)
UINT uTargetState;
hr = pRMC->ReadBitField(CRMCLink::fn70StatusAxis0, 0, 10, 2, uTargetState);
printf("Target Data = %d\n", uTargetState);
