RMCLink C++ Wrapper Class CRMCLink::IsConnected Method |
Checks to see if the link is currently connected to a controller.
bool IsConnected( bool ping ); |
ping
This parameter determines if the link should try sending a test communication with the controller before deciding whether the connection is still established. Specify true to do the test communication, or false to determine if the connection is established based on the last communication attempt. This parameter is ignored if the connection is known to be closed.
Returns true if the connection is established (after a ping is sent out if ping is set to true). Otherwise, returns false.
This method is synchronous, which means that it will not return until the method is completed. If ping is false, then it will return immediately. If ping is true, then it may take several seconds to complete. If this method is called on the main thread, then the application will likely be unresponsive until this method completes. For applications where this is not acceptable, this and other synchronous methods should be called from a worker thread, and may use the CancelRequest method to cancel an in progress request.
The following code example illustrates the use of the IsConnected method.
// Do some long task...
// Check to see if the link is still connected.
if ( pRMC->IsConnected(true) )
printf("Connection is still made.\n");
// Use the connection...
else
printf("Connection has been broken.\n");
