RMCLink C++ Wrapper Class CRMCLink::Disconnect Method |
Closes the connection associated with this CRMCLink object, if one has been established.
void Disconnect(); |
On serial connections, the serial port will be released for use by other applications. On Ethernet connection, the TCP/IP connection will be closed.
This method is synchronous, which means that it will not return until the link is disconnected. However, disconnecting generally takes only a fraction of a second.
WARNING: For Ethernet connections, it is highly recommended that the connection not be disconnected and re-connected between transactions. Doing so will have lower performance, and more importantly, each call to Connect() will consume a TCP connection in the Windows operating system. This TCP connection will not be fully released by the operating system until typically 2 minutes after Disconnect() is called. Therefore, it is possible to consume all available TCP connections by repeated calls to Connect()/Disconnect() and as a result be unable to re-connect over RMCLink or even adversely affect other applications running on the same PC.
The following code example illustrates the use of the Disconnect method.
float afData[2];
afData[0], afData[1]);
