RMCLink C++ Wrapper Class CRMCLink::CreateUSBLink Method |
Creates an instance of the CRMCLink class for communicating with a controller (RMC70, RMC150, or RMC200) over a USB port.
static CRMCLink* CreateUSBLink( enumDEVICETYPE devType, LPCTSTR deviceID ); |
devType
Specifies which type of RMC will be linked to. It must be either dtRMC70, dtRMC150 or dtRMC200.
deviceID
Specifies which controller to connect to over the USB port:
RMC75E: The controller’s 10-digit serial number in the format ”7573xxyyzz”.
RMC150: The Ethernet (MAC) Address in the format ”00-50-A0-xx-yy-zz”.
RMC200: The CPU module's serial number in the format ”22Cyynnnn”.
On success, a pointer to a newly allocated CRMCLink object is returned. On failure, NULL is returned.
Notice that this method does not in any way try to connect to the controller. This method simply creates the CRMCLink object. To connect to the device, you will need to call the CRMCLink::Connect instance method.
Because the object is only created and the connection is not made, this method returns immediately.
Free the CRMCLink class instance with the C++ delete keyword when you are done with it.
The following code example illustrates the use of the CreateUSBLink method.
CRMCLink* pRMC = CRMCLink::CreateUSBLink(CRMCLink::dtRMC70, _T("7573091001"));
float afData[2];
afData[0], afData[1]);
CRMCLink Class | RMCLink C++ Wrapper Class | CRMCLink::enumDEVICETYPE
