RMCLink C++ Wrapper Class CRMCLink::CreateSerialLink Method |
Creates an instance of the CRMCLink class for communicating with a controller (either RMC70 or RMC100) over a serial port.
static CRMCLink* CreateSerialLink( enumDEVICETYPE devType, LPCTSTR portName ); |
devType
Specifies which type of RMC will be linked to. It must be either dtRMC70 or dtRMC100.
portName
Specifies the serial port to use for communicating with the device. Typical names include "COM1" and "COM2".
On success, a pointer to a newly allocated CRMCLink object is returned. On failure, NULL is returned.
Notice that this method does not in any way try to connect to the controller. This method simply creates the CRMCLink object. To connect to the device, you will need to call the CRMCLink::Connect instance method. This method will support any com port on the PC.
Because the object is only created and the connection is not made, this method returns immediately.
Free the CRMCLink class instance with the C++ delete keyword when you are done with it.
The following code example illustrates the use of the CreateSerialLink method.
CRMCLink* pRMC = CRMCLink::CreateSerialLink(CRMCLink::dtRMC70, _T("COM1"));
float afData[2];
afData[0], afData[1]);
CRMCLink Class | RMCLink C++ Wrapper Class | CRMCLink::enumDEVICETYPE
