RMCLink C++ Wrapper Class CRMCLink::enumFILENUMBER200 Enumeration |
File numbers used when communicating with the RMC200. These are often used as the file parameter in read and write methods.
fn200ControllerInfo = 7 |
Basic controller read-only information |
fn200IndDataValues = 8 |
Indirect Data Map Values |
fn200IndDataMap = 12 |
Indirect Data Map Definition |
fn200CommandArea = 16 |
Command Registers for all axes |
fn200ControllerRegs = 18 |
Controller Status/Configuration Registers |
fn200DiscreteIO = 20 |
Discrete I/O Registers |
fn200TaskManager = 21 |
Task Configuration Registers |
fn200PlotManager = 22 |
Plot Layout Registers |
fn200ImageArea = 23 |
Image Upload/Download Area |
fn200AxisAssignActive = 24 |
Axis Definitions (active) |
fn200AxisAssignNew = 25 |
Axis Definitions (new) |
fn200ModuleDefs = 26 |
Module Definition Registers |
fn200CommConfig = 112 |
Communication Configuration Registers |
fn200AddressMapDF1 = 113 |
DF1 Address Map |
fn200AddressMapMB = 114 |
Modbus Address Map |
fn200AddressMapFINS = 115 |
FINS Address Map |
fn200AddressMapPN = 116 |
PROFINET Data Record Address Map |
fn200ModuleBase = 128 fn200ModuleSlot0PS = 129, fn200ModuleSlot1CPU = 130, fn200ModuleSlot2 = 131 ⁞ fn200ModuleSlotn = 129 + slot n ⁞ fn200ModuleSlot14 = 143 |
Module Type and Status Registers |
fn200TaskStatus0 = 192 ⁞ fn200TaskStatusn= 192 + task n ⁞ fn200TaskStatus63 = 255 |
Task Status Registers |
fn200StatusAxis0 = 256 ⁞ fn200StatusAxisn= 256 + axis n ⁞ fn200StatusAxis127 = 383 |
Axis Status Registers |
fn200ParameterAxis0 = 384 ⁞ fn200ParameterAxisn= 384 + axis n ⁞ fn200ParameterAxis127 = 511 |
Axis Parameter Registers |
fn200Plot0CfgSts = 512 ⁞ fn200PlotnCfgSts = 512 + plot n ⁞ fn200Plot63CfgSts = 575 |
Plot Configuration/Status Registers
fn200Plot0DynUA = 576 ⁞ fn200PlotnDynUA = 576 + plot n ⁞ fn200Plot63DynUA = 639 |
Plot Dynamic Upload Area |
fn200Plot0StaticUA = 640 fn200Plot1StaticUA = 656 fn200Plot2StaticUA = 672 fn200Plot3StaticUA = 688 |
Plot 0-3 Static Upload Area |
fn200VarCurValues = 1024 |
Variable Table - Current Values |
fn200VarInitValues = 1280 |
Variable Table - Initial Values |
fn200VarAttributes = 1536 |
Variable Table - Attributes |
