Position-Pressure Overview
The RMC100 excels at smoothly transitioning from position to pressure (or force) control while in motion. This requires two axes: one for the position control and one for the pressure control. When set up for position/pressure control, the RMC100 effectively controls these two axes as one unit.
For information on only controlling pressure or force, see the Controlling Solely Pressure or Force topic.
For complete instruction on how to set up, tune and control a position/pressure system, read the following topics:
  1. This topic.
  2. Position/Pressure Setup
  3. Tuning a Position/Pressure System
  4. Position/Pressure Example
Required Equipment
To control position to pressure transitions, an RMC100 with the following options is required:
Types of Pressure Control
The RMC100 offers two types of pressure control:
Three Basic Modes of Operation
There are three basic modes that must be understood in order to control pressure or force:
The axis may leave pressure regulating mode and return to Position Control by giving a move command without the Monitor Pressure Mode bit set.
A typical position/pressure application uses the above modes in the following order:
  1. A move is made in position control mode to the starting position.
  2. A move is made in the direction of increasing pressure with the monitor pressure bit set (pressure monitoring mode).
  3. When the pressure reaches Pressure Set A, the axis enters pressure regulating mode. Pressure can now be controlled.
  4. To exit pressure control, a move is made with the Monitor Pressure bit cleared.
To perform position/pressure control on your system:
