Position-Pressure Example (Part 1)
This is a complete step-by-step example of setting up and tuning a position/pressure hydraulic axis. Even if your system does not have pressure control, it may be useful to read the position portions of this example.
This example is divided into 3 parts with subparts:
(each section is a separate help topic)
  1. Setup (this topic)
  2. Position Tuning
  3. Pressure Setup
  4. Pressure Tuning
  5. Transition Tuning
This example uses an RMC101-M1-A1-ENET, a common configuration for position/pressure control. The system itself is a hydraulic cylinder with MDT feedback (start/stop rising edge) and analog double-ended pressure feedback, making force control possible. If the pressure feedback were single-ended, only pressure control would be possible.
  1. System Design
    A typical hydraulic system for position/pressure control looks like this:
Note the good design practices:
  1. Wiring
It is important to wire the transducer correctly. See MDT Wiring and Analog Wiring for details.
For this example the system is wired as follows:
  1. RMCWin View
When connected to this RMC, the main RMCWin window looks as follows:
  1. Configuring the pressure/force axes.
To configure the pressure axis, the following steps are performed:
The RMCWin window now looks like this:
  1. Configuring the MDT position axis.
    To scale the MDT position axis, the following steps are performed:
  1. Scaling the pressure/force axis.
  1. Scaling the MDT position axis.
The main RMCWin window looks now like this:
This example is continued in the next topic.
