Each device on the Modbus Plus network must have a unique ”r;node address”. Each node address is a number between 1 and 64. The user changes the RMC’s node address using RMCWin with the following steps:
On the Tools menu, click Module Configuration.
In the Slot list, click the Modbus Plus item.
Click Slot options.
In the Node Address box, type the desired node address.
Click Update RMC.
The Update Module Configuration dialog box will be displayed to indicate the progress. If the module could not be reset automatically, you may be prompted to reset the module manually.
Click Close from the RMC Configuration dialog.
