LCD Display Terminal Overview
Using the LCD420 display as documented requires the following components:
Prior to the December 4, 2000 release, the LCD420 display had a different keypad and the firmware behaved much differently. Users of the previous version may choose to keep their older displays, in which case it is important to not update the firmware to 20001204 or newer. Otherwise, contact Delta for details on upgrading to the new LCD420 display and firmware.
The LCD420 is an accessory available for the RMC100 series motion controllers. The LCD420 is a hand-held or panel-mounted terminal with a 4-row, 20-column LCD display and a 20-key keypad. This terminal can be programmed using RMCWin's LCD Screen Editor. The following list summarizes the LCD420 display capabilities:
For details on using the LCD420 terminal, see Using the LCD420 Terminal.
For details on programming the LCD Terminal, see LCD Screen Editor: Overview.
