Set Mode Command
Character: M
Decimal: 77
Hexadecimal: 0x4D
Command Value: New Mode value
This command is used to change the Mode for the current command in one of several ways. The changes take place immediately.  The allowed bits (described below) are copied from the Command Value to the Mode field for this axis.  The following Mode bits can be changed with this command:
